Home » Sponsored » Pi Speakers » mulling over crossover questions. Wayne? Anybody?
Re: A few useful documents [message #42873 is a reply to message #42840] Sat, 01 November 2003 12:53 Go to previous messageGo to previous message
Hi Wayne,
Not to complain, because you are so generous with such good
info, but the spice.zip install seems to be broken. On two different
computers, when I run aimsp32.exe, it tries to install the previous
program I installed instead of Spice. Any idea what's going on?
On the first one, I even when hunting for setup.exe from the last
installed program and deleted that. No help. I think WinZip is
common between the two, FWIW.
The on-topic question I had is about the crossovers. Doesn't including
a significant series resistor alter the crossover frequency of the cap(s)
and coil? The reason I ask is that you've suggested in the past that the
Eminence 1.6K crossovers are OK to use along with the HF comp
components verses making up the whole x-over by hand.
Thx, Chris
Previous Topic: How to downsize a cabinet's volume?
Next Topic: Any experience alpha 15 or another for open baffle ????
Current Time: Sat Nov 28 19:18:36 CST 2026
