Home » Sponsored » Pi Speakers » Pictures
Pictures [message #42811] Mon, 27 October 2003 01:41 Go to previous message
Hey everyone,
Here are some pictures of my half-way completed towers for the 2225's, 2370's HF horns, and also my own midrange horns I built. These towers arn't finished yet, but pictures are always fun, right? So here they are!
Above picture shows the bottom part of the enclosure. It goes inside the outer panels, which is Tasmanian Oak.
Here are the front baffle boards for the enclosures. On the bottom is the JBL 2225 15" hole, the middle is the hole for the tractrix horn,
and the top is the hole for the 2370 horn. Below the 2225 hole there should be two holes for the ports, but I havn't cut them out yet. The 2225H is PiAligned. I'll probably cut the holes for the ports tomorow or something.
Above shows how the front panels are going to attach. Hence you can see what I meant by those boxes going at the bottom. The thing on the right hand side is the other box tipped on its side. You can see the proper veneered bottom has been attached to the plain MDF, so its double layer 18mm MDF.
Above shows the sides of the enclosures. Pre-veneered MDF in Tasmanian Oak! These go on the sides of the boxes like the picture above so you can see how it goes togethor.
Another shot of the front and how it attaches to the 2225H box. Top left hand corner is a block out from my thumb.
The 2225 box has two layers of 18mm MDF for 36mm total thickness for the bass section! It's gonna be heavy overall too. The outer tasmanian oak veneered MDF panels are bevel cut to 45degrees so you cant see the edges. I'll post more pictures when they are done.
Adrian
Previous Topic: my system..
Next Topic: check out these speakers on Audiogon.
Current Time: Sat Nov 07 18:52:55 CST 2026
