Home » Sponsored » Pi Speakers » check out these speakers on Audiogon.
check out these speakers on Audiogon. [message #42807] Sun, 26 October 2003 15:07 Go to next message
drguayo is currently offline  drguayo
http://cgi.audiogon.com/cgi-bin/auc.pl?spkrfull&1067908076
they look like they would be similar to the Stage Series Theatre 4 pi(same components excepting the xover and horn flare).
Re: check out these speakers on Audiogon. [message #42819 is a reply to message #42807] Mon, 27 October 2003 16:50 Go to previous message
GrantMarshall is currently offline  GrantMarshall
They definitely look interesting. Not pretty, but interesting. Components used are respectable. As an example of nice looking speakers check out the Pi 4's at http://dsb.8m.com/pipics/4Pi_Theater_Garland_01.jpg. There are a lot of pictures of Pi 4's at http://dsb.8m.com/pipics/pipics.htm.
Reserve not met so the next question is what the reserve is. The seller talks about $480 into woofers/ compression drivers. 811's are another $100 but probably came with the Santiago cabinets. The crossovers $50-75 and cabinets ????
They look bigger than 4 Pi's but I couldn't find dimensions on the Santiago cabinets in the high efficiency or vintage forums. Definitely not as pretty as some of the 4 Pi's. New York address so you could probably pick them up to make sure you weren't getting ripped off with blown drivers etc.
Grant.
Previous Topic: Pictures
Next Topic: Society for the Clothing of Speakers; Bmar, pres.
Current Time: Sun Oct 25 09:41:54 CDT 2026
