Home » Sponsored » Pi Speakers » Horn advice
Re: Horn advice [message #42707 is a reply to message #42699] Wed, 15 October 2003 05:31 Go to previous messageGo to previous message
Andrewbee is currently offline  Andrewbee
What's your budget and amplification?
I would rather stay South of 1K.
I have an AKSA 55w/ch that has killer bass control as well as an old Carver with ~ 150w/ch
Does your room have corners suitable for cornerhorn loading at one of the 15' ends?
Yes.
If so, I'd be inclined to put JBL 2241's in a π cornerhorn configuration at each corner.
Okay, so which corner horns would you recommend and why?
Also any reason for a 18" as against a 15"? Is it because the room is so large?
When i think of a 18" its huge. I have to put my bigscreen tv between the corners as well. I should have told you that before.
Thanks
Andrew
Previous Topic: Theater 3 Pi plans
Next Topic: Great Tube Art
Current Time: Fri Nov 13 08:52:37 CST 2026
