Home » Sponsored » Pi Speakers » Newbie, need help about series speaker
Re: The problem is the damping factor... [message #42701 is a reply to message #42696] Tue, 14 October 2003 20:59 Go to previous messageGo to previous message
I'd have to disagree with this... A) there's no evidence to suggest that wiring series would "mess up" bass response, and B) if anything, it would improve damping factor, as damping factor is increased as impedance increases.
In any event, modern amps have such high damping factors that even such an effect is meaningless unless you are running the amp way below its rate impedance... This is audiophyle nonsense, no offense intended...
Series, parallel, whatever... Series wiring will give you no increase in sensitivity, but will double your power handling. However, as your friend mentioned, there will be crossover interactions when wiring mult-way speakers in series with each other. Single drivers are no problem.
Adam
Previous Topic: Single Driver doubter no more
Next Topic: Canadian Pi Owners - experience with customs on shippment?
Current Time: Sat Nov 07 00:28:46 CST 2026
