Home » Sponsored » Pi Speakers » Wayne, JBL 2118J or JBL 2123J?
Wayne, JBL 2118J or JBL 2123J? [message #42664] Fri, 10 October 2003 12:24 Go to next message
Tubo is currently offline  Tubo
Wayne, which Pi speaker could I build with either the JBL 2118J or the 2123J?
the 2118J is 16 ohm 97 db
the 2123J is 16 ohm 101 db
I understand the 2123 is more of a midrange driver, but I have subwoofers so deep bass is not a concern.
Which tweeters could I use? Is there an opportunity here for a crossoverless design (the 2123, specially, falls off a cliff after 5K Hz)?
Thanks, Al Lau
Good stuff! [message #42666 is a reply to message #42664] Fri, 10 October 2003 15:46 Go to previous messageGo to next message
Hi Al!
I really like the JBL 2123, much like the 2105 that I used for so many years in systems with 2205's.
I'm certain that the 2118 is an excellent part too, and you may find it to be similar to 2115's. I always loved those, and I think I may investigate the 2118 in this context. But I haven't yet, so I really can't form an opinion.
Wayne
Re: Wayne, JBL 2118J or JBL 2123J? [message #42685 is a reply to message #42664] Mon, 13 October 2003 10:48 Go to previous message
dwkurfma is currently offline  dwkurfma
Check out the High Efficiency forum. There are some tips there. I haven't been able to track it down but one fellow there built a 2235/2118/2404 combo. The stock cross-over from the kit supplier had serious problems, but a revised version from Madisound modeled extremely well. I have a hard copy somewhere but I don't know if I have electronic. I will hunt around. This was a true three way, not a two way with woofer, though you can stretch the 2118 a bit. JBL had a model with dual 2118 drivers and a single 2404 a good number of years ago. Can't give you a model right now because my literature is packed away in a box somewhere.
If you want more info, holler, and I'll see what I can find.
Dan
Previous Topic: Altec 416C vs JBL 2226 in a 2-way system
Next Topic: Impedance at resonance and tube amps
Current Time: Sat Oct 24 20:14:04 CDT 2026
