Home » Sponsored » Pi Speakers » crossover questions...
crossover questions... [message #42629] Wed, 08 October 2003 05:52 Go to next message
Larry Acklin is currently offline  Larry Acklin
I have a pair of JBL 2425J 1" exit drivers, 16 ohm. If I want to use them in a 2 or 3 way box, how can I reconfigure the crossover so it treats the drivers properly, but still presents 8 ohms to the amp?
They would be bolted to CD horns, so the top octive compensation would be a plus.
I know that the cap values change for a 16 ohm driver, but I'm a little hazy on what determines the nominal value the completed system presents to the amp.
Yes, I know I could just tack a 16 ohm resistor across the driver, but that kills the sensitivity.
Also, would it be possible to design a passive crossover (high-pass)
that could do the same thing- present an 8 ohm load, but have the 16 ohm driver inside?
Thanks
Larry
crossover answers [message #42637 is a reply to message #42629] Wed, 08 October 2003 14:40 Go to previous message
You answered your own question - You can put a resistance in shunt to set the load. If the compression horn needs padding and/or HF compensation, you can form a voltage divider and also be able to use it to set filter Q and high-frequency augmentation. Alternately, you can use a transformer for impedance matching. It's all a balancing act, of setting goal and priorities and building to suit.
Previous Topic: THD woofer measurement-what mic
Next Topic: Hi Guys! How about the ESG1 in a Theater 4?
Current Time: Sun Nov 01 03:23:40 CST 2026
