Home » Sponsored » Pi Speakers » Omega18 vs Selenium18 sub
Omega18 vs Selenium18 sub [message #42532] Sat, 20 September 2003 17:56 Go to next message
Hi Wayne,
For fun, I compared the Omega18 against the Selenium 18SW1P
18" subwoofer. Both PiAlign and BoxPlot give a ~3.3 cu. ft. box
for the Omega, which seems pretty small for an 18"er. The
Selenium has similar specs except for Qms. The difference is
between 5.53 for the Omega and 10.93 for the Selenuim. Vas is
12.5 vs. 13.3. The freq. plot for the two show the Omega -3dB
around 58Hz, and the Selenium around 36. Does the difference
in the specs make that much difference? Aside from the obvious
answer, why?
BTW, the BoxPlot box for the Selenium is 7.75cu ft. With a similar
sized box for the Omega, you get a sort-of ESB alignment, with a
similar -3dB point. Any thoughts? Anyone tried this Selenium?
Thx, Chris
Re: Omega18 vs Selenium18 sub [message #42533 is a reply to message #42532] Sun, 21 September 2003 08:33 Go to previous messageGo to next message
The Omega 18 is really tuned as a high-power midbass and not so much as a subwoofer. You can put it in a cabinet giving it an EBS alignment, and it will work below 40Hz. But the Omega 18 is really best suited for 40Hz up in high-power applications.
While not being familiar with the Selenium 18SW1P, its specs indicate that it is tuned to be used lower. It will generate more output in the bottom octave at the expense of performance higher up. These kinds of optimizations are functions of the specifications of the woofer, which were designed to meet a specific goal.
The Omega 18 is more like the JBL 2241, while the Selenium 18SW1P might be more like the JBL 2245. Which is better for you really depends on what you plan to use them for.
Re: Omega18 vs Selenium18 sub [message #42534 is a reply to message #42533] Sun, 21 September 2003 11:07 Go to previous messageGo to next message
Hi Wayne,
I guess my question is about how to select a driver by reading its
specs. In this case, both have an Fs of 29Hz. The only remarkable
differences are the one point is Vas, and the significant difference
in Qms. Is it reasonable to think you can predict a speakers freq.
performance based on reading specs alone, or does this capability
come from running the numbers on a variety of drivers to get a
feel for how each of the specs effect the result? In other words,
plain old experience. I there a table that describes how each
of the specs inter-relate? Something like, "Vas and box size are
proportional. Qms is proportional to low end performance, but the
optimum value is around blah with a Vas around blah."
Thx, Chris
Re: Omega18 vs Selenium18 sub [message #42535 is a reply to message #42534] Sun, 21 September 2003 13:16 Go to previous messageGo to next message
There is a reliable correlation of the response characteristics of a speaker and it's electro-mechanical parameters. You can expect the formula to guide you in this regard. The best thing to do is model a system based on speaker parameters to see what you can expect. So I'd always recommend that you model the system when considering a part or comparing it with another. These days, modeling is not very difficult at all.
Another thing to consider is that the response curve can be modeled pretty well, but there are important properties that don't show up in this sort of model. Cone flex introduces behaviors that aren't considered in T/S models, but they are usually not an issue below a few hundred Hertz. Distortion performance is an important property that isn't described in the T/S electro-mechanical model either. It's largely the result of electro-magnetic properties, so you would need to model the motor system to determine LF distortion. My point is that there are some properties that determine quality to a great degree, but that aren't described in the electro-mechanical terms usually used to calculate cabinet dimensions. T/S models are pretty accurate at predicting bass response though.
Re: Omega18 vs Selenium18 sub [message #42536 is a reply to message #42535] Sun, 21 September 2003 19:28 Go to previous messageGo to next message
Hi Wayne,
Thanks for the comments...
>at all.
Maybe that's my problem. I'm accustomed to having all the data available and being able to run command line tools in batch mode. If I could have that database of data, I could write the tools, then grep for the result I'm looking for. Now that's what I call a speaker selector! This whole enter the data, interactive GUI thing just isn't my bag. Way too slow.
OK. Its becoming more clear now, although depressingly so. It seems the best defense against lower quality motors is cash. Oh well...
Thx, Chris
GUIs [message #42537 is a reply to message #42536] Mon, 22 September 2003 05:31 Go to previous messageGo to next message
toxicport.e is currently offline  toxicport.e
lol yeah everything is yummy graphics thesedays,atleast winisd has functions that work..
just look at the games of today-all graphics,no story
DOS u say? command line :o whats that ! hahha
cd/games
my first DOS command when i was about 6,on an orange screen ,california games,xenon2,sopwith,etc etc.and the never ending game zeliard we couldnt finish,i wonder if i could get all of those agian,ive found xenon2 and sopwith2 hah
yep theres no replacement for displacement (and quality woofers)
:-D
id model in winisd pro,its fast.then to be sure,use a spreadsheet like Adrian macks,he has everything winisd does,and ofcourse you can Know whats going on because the equations are right there..
cheers
Mike
grep [message #42538 is a reply to message #42537] Mon, 22 September 2003 06:09 Go to previous messageGo to next message
Aaah, grep. I like grep and Perl, but I can't stand awk. Funny how UNIX commands all sound like you're clearing your throat or something.
Re: grep [message #42539 is a reply to message #42538] Mon, 22 September 2003 07:16 Go to previous messageGo to next message
I use grep as a concept for conversation, not so often literally.
perl is my hammer for almost all my computing nails. Unix/linux
are my bread and butter. You just can't do that stuff in Windows.
Re: grep [message #42540 is a reply to message #42539] Mon, 22 September 2003 10:15 Go to previous messageGo to next message
Have you ever used the grep utility under MS-DOS or the command line in Windows? I've got a copy because its regular expression parser sure is handy. It works pretty well, even on MS-DOS.
Re: grep [message #42543 is a reply to message #42540] Mon, 22 September 2003 15:01 Go to previous messageGo to previous message
RE: grep in DOS...
No. My PC is dual-boot, so if I have texty data and/or perl problems
to solve, I boot linux. In Windows, I just run the GUI tools and
live with whatever that provides. I know folks that use MKSTools
or something like that. You get all the unix shell commands
including grep. You can get perl for Windows also. To me, Windows
is unstable enough as is, so I add as little as possible to it and
use linux when I want that environment.
Thx, Chris
Previous Topic: Audiophile Posters
Next Topic: Newbie . . . needs help . . .
Current Time: Wed Nov 04 11:10:19 CST 2026
