Home » Sponsored » Pi Speakers » How Many beer'
How Many beer' [message #42465] Sat, 13 September 2003 19:19 Go to next message
How Many beer' before your circuit boards dont get the solder in the right spot?
Bill
Re: How Many beer' [message #42466 is a reply to message #42465] Sat, 13 September 2003 20:31 Go to previous messageGo to next message
Seven. Three if Jack Daniel's is there to help.
Cheers!
Steve
Re: How Many beer' [message #42468 is a reply to message #42465] Sat, 13 September 2003 21:37 Go to previous messageGo to next message
Depends
How bad does beer affect your hearing and how tough is your equipment? Nothing like an unintended shunt to ground to confuse a drunk. Makes fuses do neat things too.
Soldering drunk is like taking home someone from a bar. It's all good while your high, but...
Thomas
Re: See below: [message #42480 is a reply to message #42465] Sun, 14 September 2003 04:07 Go to previous messageGo to next message
CurentlyInebriatted is currently offline  CurentlyInebriatted
Whatcha buildin', Bill? [message #42486 is a reply to message #42465] Sun, 14 September 2003 06:57 Go to previous messageGo to next message
Re: 4 way active [message #42489 is a reply to message #42486] Sun, 14 September 2003 16:37 Go to previous messageGo to next message
I picked up a kit from Marchand Electronic to build a new crossover. I decided to build the solid state model XM44 with single ended and balanced connections. The tube model was a little over my head although after seeying it in the Marchand shop, It looks mint.
Anyway I was having a few and seemed like a curious question to raise! I quit after a few beers anyway. Over 1400 solder points on the main board on this baby. plus 8 stepped attenuaters, a power supply and a lot of inputs. Its a busy thing that's for sure
Bill
Re: 4 way active [message #42492 is a reply to message #42489] Sun, 14 September 2003 19:09 Go to previous messageGo to next message
Sounds cool, Bill! Let us know how it works out!
Re: Teaser [message #42505 is a reply to message #42492] Mon, 15 September 2003 15:16 Go to previous messageGo to next message
Hi Wayne!
This is how it's looking so far. Still have all the outputs to wire in and the all the module boards to put together. This is the 4 way cross over and I just added a summed sub output tonight, both single ended and balanced. All Burr Brown OpAmps too.
This is the sub crossover and equalization unit called the Bassis. Its a duel channel unit so I just use one side.
I listened to the Marchand Tube crossover and it sounds very nice. The attenuator components are also very nice in that model. You should get going on the design you have been working on. I'm sure your busy or you would be on it. Always yet another project eh?
Bill
Sweet! [message #42506 is a reply to message #42505] Mon, 15 September 2003 15:39 Go to previous message
Oh, now, that really looks nice. I'll bet you're proud of it! I want to check it out next time we're in Lima together.
Previous Topic: Build or buy....which is cheaper?
Next Topic: If I have two drivers in a box in parallel...
Current Time: Wed Nov 04 22:28:34 CST 2026
