Home » Sponsored » Pi Speakers » Altec Pi again, more questions wayne!
Altec Pi again, more questions wayne! [message #42357] Thu, 04 September 2003 05:44 Go to previous message
I have been looking at the posts on altec, but have some unanswered questions. The woofers I have available are the 515 8G, (not very good in reflex setup, designed for horn on front, with reflex on back, like 825/828 cabs) and also 416 8c, much better for reflex. I found info on dimensions for the 416 b, and when I ran the figures on your program, I came up with the same figures. However, when I ran the 416 8C figures,( which are slightly different in a few regards than the 416 b), I came up with a slightly larger box, but a much smaller port? Is this correct? i can send you the numbers if you need them. secondly, do you, or anyone know if the 515 8G will work in one of your corner horns? This is the driver used in the exemplar, horn on front, reflex on back, quite sucessfully, and since your corner horn seems to be a reflex firing into a corner horn, I thought it might work, but I located no posts on this driver used in this fashion. lastly, what is the cubic feet of the theater Pi?
Thanks Wayne, I aapreciate your time,
Russellc
Previous Topic: Where the hell is Replay?
Next Topic: martin audio em 26 upgrade
Current Time: Sun Nov 01 15:20:19 CST 2026
