Home » Sponsored » Pi Speakers » Bass Horn For Altec Driver
Bass Horn For Altec Driver [message #42340] Tue, 02 September 2003 16:33 Go to next message
mgzny is currently offline  mgzny
Hi Wayne et al:
Any suggestions for a cabinet for a the Altec 414Z 12' woofer?
I am planning to mate with Altec 802D compression driver.
Aprreciate anyone's help. Have not tracked down the TS specs yet.
Thanks to all, Mark
Altec π 's [message #42345 is a reply to message #42340] Tue, 02 September 2003 20:04 Go to previous messageGo to next message
I don't have any direct experience with the Altec 414, but there are several here that have used this and other Altec midwoofers. Seems to me that they are usually used in a rather large bass-reflex cabinet, many of which include truncated (midrange) horns. I'm sure you're aware of that configuration - It's one of Altec's most popular, with the driver installed in a front-loaded small horn and with the back chamber being a large bass-reflex cabinet.
I've also known many that used them in two-way speakers with a simple (non-horn loaded) bass-reflex design for the midwoofer and a large-format HF horn for the vocal overtone range up. Seems like PiAlign recommended something like 9 cubic feet tuned to 30Hz or so, but I may be thinking about Altec 416's.
Altec Driver T/S Parameters [message #42346 is a reply to message #42340] Wed, 03 September 2003 00:21 Go to previous messageGo to next message
Re: Altec Driver T/S Parameters [message #42347 is a reply to message #42346] Wed, 03 September 2003 09:21 Go to previous messageGo to next message
Thanks for the info. Had tried Great Plains, no specs for 414Z though.
Goiung to keep looking and asking.
Regards, Mark
Re: Altec π 's [message #42348 is a reply to message #42345] Wed, 03 September 2003 09:26 Go to previous messageGo to next message
Thanks Wayne:
Looking through the Altec posts, saw mention of someone using
the 515 driver in a pi cabinet, saw same on BD-design forum.
Any chance the 6pi would work with the 414Z? I know I have to
track down the TS #s.
Thanks again, Mark
Re: 414Z=414A without a magnet cover (nt) [message #42355 is a reply to message #42340] Wed, 03 September 2003 22:49 Go to previous messageGo to next message
tubefever is currently offline  tubefever
nt
Re: Altec π 's [message #42356 is a reply to message #42348] Thu, 04 September 2003 00:26 Go to previous message
You're right - You'll need to know the woofer parameters and then calculate cabinet dimensions with PiAlign. But I suspect that the six π will work very well with this driver - Altec tended to make parts that are suited for this sort of design.
Previous Topic: Pi subwoofer plans please...
Next Topic: Where the hell is Replay?
Current Time: Sun Nov 01 14:07:56 CST 2026
