Home » Sponsored » Pi Speakers » measurement questions
it's Greek to me [message #42284 is a reply to message #42283] Tue, 26 August 2003 14:11 Go to previous messageGo to previous message
artsybrute is currently offline  artsybrute
Hey, I'm just a hobbyist trying to build a speaker.
"Impedance can be found by measuring the voltage across the speaker motor and calculating the current through the circuit."
X = 2πFL for inductive circuits. I assume I find resonance (and from this paper I understand that resonance is where inductive reactance and capacitive reactance are equal), then plug the values into that formula. But I don't know the inductance. Furthermore, from I=E/Z, we can derive Z=E/I. Fine. The signal generator I ordered puts out 1.2V RMS. I don't know the current it puts out.
I'm to put a 10 ohm resistor in series with the speaker coil. Am I to break the circuit at Zmax and Zmin and measure current draw with a milliameter?
Do I then measure voltage drop across the coil once I reconnect the circuit?
"This reactive circuit (inductance and resistance) forms a voltage divider, so you can use Ohms law and reactive circuit formulas to determine the impedance of the motor."
We put the resistor in series with the coil. I don't understand how this is a voltage divider. Where are we dropping the divider to ground?
These questions certainly must seem naive to you, but again, I'm a hobbyist who just wants to build a speaker.
Previous Topic: Interpreting speaker response curves
Next Topic: Back from the Vet and de-Wormed
Current Time: Sun Nov 01 16:26:45 CST 2026
