measurement questions [message #42280] |
Tue, 26 August 2003 12:06 |
artsybrute
Messages: 56 Registered: May 2009
Baron |
Hi Wayne, Some questions regarding measuring speaker parameters: 1. "So simply measure the DC resistance of the driver with an ohmmeter, and use the impedance found when measuring the driver's resonant frequency for Zmax." I'm missing something here. All the tests until this point seem to give frequencies, not impedances. How do I determine the impedances Zmax and Zmin? 2. It seems that the scope is used to determine highest voltage and .707 times that. Can I just use a voltmeter instead? 3. When taking these measurements, is there a way to determine the speaker sensitivity? Should I just use an SPL while running the 1 volt RMS with the resistor? Will sensitivity change unequally for the drivers due to their different ensclosure volumes? TIA
measurement answers [message #42281 is a reply to message #42280] |
Tue, 26 August 2003 13:00 |
Messages: 18784 Registered: January 2001
What we're looking for are impedance values at specific frequencies. So, for example, DC resistance is impedance at 0Hz and Zmax is impedance at the resonant frequency. Zmax is described by a frequency and an impedance. If you measure voltage with a scope, you'll see peak values and can find RMS by multiplying by 0.707. If you measure with a DVM, you'll read RMS values and can calculate peak by dividing by 0.707. As for SPL, sure, you can put a microphone 1 meter away and supply a 2.83v test signal to find the 2.83v/M level, or whatever levels you wish. But below 100Hz, the cabinet will have a lot of influence so keep that in mind. For that matter, so will the room unless you do the acoustic measurements outdoors.
Re: measurement answers [message #42282 is a reply to message #42281] |
Tue, 26 August 2003 13:02 |
artsybrute
Baron |
I guess I'm a bit thick. "What we're looking for are impedance values at specific frequencies. So, for example, DC resistance is impedance at 0Hz and Zmax is impedance at the resonant frequency. Zmax is described by a frequency and an impedance." OK, I can determine the frequency but how do I find the impedance?
it's Greek to me [message #42284 is a reply to message #42283] |
Tue, 26 August 2003 14:11 |
artsybrute
Baron |
Hey, I'm just a hobbyist trying to build a speaker. "Impedance can be found by measuring the voltage across the speaker motor and calculating the current through the circuit." X = 2πFL for inductive circuits. I assume I find resonance (and from this paper I understand that resonance is where inductive reactance and capacitive reactance are equal), then plug the values into that formula. But I don't know the inductance. Furthermore, from I=E/Z, we can derive Z=E/I. Fine. The signal generator I ordered puts out 1.2V RMS. I don't know the current it puts out. I'm to put a 10 ohm resistor in series with the speaker coil. Am I to break the circuit at Zmax and Zmin and measure current draw with a milliameter? Do I then measure voltage drop across the coil once I reconnect the circuit? "This reactive circuit (inductance and resistance) forms a voltage divider, so you can use Ohms law and reactive circuit formulas to determine the impedance of the motor." We put the resistor in series with the coil. I don't understand how this is a voltage divider. Where are we dropping the divider to ground? These questions certainly must seem naive to you, but again, I'm a hobbyist who just wants to build a speaker.
Driver Quality [message #42287 is a reply to message #42285] |
Tue, 26 August 2003 22:12 |
toxicport.e
Messages: 48 Registered: May 2009
Baron |
off topic- shiva,tempest,XLS,dpl12 compared on this site.somehow the DPL looks better than shiva i think.. are these tests good enough to warrant calling the DPL12 lower distortion? at moment im designing my front chamber /horn expansion twist-change in dimension.>
if the DPL12 is less distortion,is it worth choosing it instead of shiva? if i could even order it. _Mike
Re: Thanks [message #42288 is a reply to message #42286] |
Wed, 27 August 2003 08:42 |
Gabriel
Messages: 32 Registered: May 2009
Baron |
Hi, Please see this link, maybe it can help you out with your measurement, and just the information, all the voltage that used in this link is AC, so you can use AC voltmeter: http://sound.westhost.com/lr-passive.htmRegards, Gabriel
