Home » Sponsored » Pi Speakers » anyone in the NY/NJ/CT area familiar with Pi Horn concepts?
Re: obtaining driver parameters [message #42271 is a reply to message #42270] Mon, 25 August 2003 12:58 Go to previous messageGo to previous message
You'll need a good DVM or an oscilloscope, a signal generator and a resistor to make measurements. The documentation included with the PiAlign program describes how to make measurements with these instruments. You can also use specialized test equipment made specifically to obtain T/S specs. Or you can use a computer-based measurement system.
Prices of each of the computer-based systems are varied. Some are pretty expensive but one of the popular freeware programs is Audia's Speaker Workshop. This system is popular because it measures system response. Another program that is popular for finding driver parameters is Claus Futtrup's Driver Parameter Calculator. This program is made specifically for obtaining the parameters you need. If you already own a computer and sound card, then use of these PC-based systems might be the most attractive option for you.
In any case, after you've obtained Frd, Vas and Qts, you'll enter these values into PiAlign. Actually, you'll want to enter the reciprocal (1/Qts) of Qts as Qd, Vas as Vad and Fts as Frd. The program will then recommend cabinet and port dimensions for you. For more information, please read the "readme.txt" file in the PiAlign distribution archive.
Previous Topic: A few words about the stock JBL 3677S speaker......
Next Topic: Instaling Pi studio 3 inside enclosures like this:
Current Time: Thu Nov 05 07:45:34 CST 2026
