| anyone in the NY/NJ/CT area familiar with Pi Horn concepts? [message #42268] |
Mon, 25 August 2003 10:20  |
artsybrute
Messages: 56 Registered: May 2009
Baron |
Hi all, Well, finally got the preamp working (with a lot of help from my friends). The next project is to build the Pi Seven Theater Series cornerhorns. Since I do my sanding outside, it's time to get started. Before ordering Eminence drivers, I'd like to determine if any of the woofers I have would sound better. I have a pair of 15" paper cone woofers from a pair of old Magnavox consoles and a pair of 1961 Jantzen hybrid electrostatics that use a very nice pair of red 11" woofers that sound really nice. I've tried to figure out the Pi software and methods used to measure speaker attributes, but I cry uncle. Anyone in the area who'd like to help out?
| obtaining [message #42270 is a reply to message #42269] |
Mon, 25 August 2003 12:20   |
artsybrute
Baron |
I just don't know how to obtain the measurement parameters: 1. What tools or equipment I need 2. How to use them 3. What to input into which program In other words, the whole thing.
| Re: obtaining driver parameters [message #42271 is a reply to message #42270] |
Mon, 25 August 2003 12:58   |
You'll need a good DVM or an oscilloscope, a signal generator and a resistor to make measurements. The documentation included with the PiAlign program describes how to make measurements with these instruments. You can also use specialized test equipment made specifically to obtain T/S specs. Or you can use a computer-based measurement system. Prices of each of the computer-based systems are varied. Some are pretty expensive but one of the popular freeware programs is Audia's Speaker Workshop. This system is popular because it measures system response. Another program that is popular for finding driver parameters is Claus Futtrup's Driver Parameter Calculator. This program is made specifically for obtaining the parameters you need. If you already own a computer and sound card, then use of these PC-based systems might be the most attractive option for you. In any case, after you've obtained Frd, Vas and Qts, you'll enter these values into PiAlign. Actually, you'll want to enter the reciprocal (1/Qts) of Qts as Qd, Vas as Vad and Fts as Frd. The program will then recommend cabinet and port dimensions for you. For more information, please read the "readme.txt" file in the PiAlign distribution archive.
| Re: obtaining driver parameters [message #42272 is a reply to message #42271] |
Mon, 25 August 2003 13:17   |
artsybrute
Baron |
Thanks Wayne, I have a scope, but my signal generator took a dive this weekend. I was going to order an inexpensive Temna (sine only) or Allied Electronics (sine and square wave) to replace it. For these tests, what do I need? Can I get away with just 1 Khz or do I need a range? Also, what size and value resistor? I'm accustomed to chasing a circuit with a scope, just by checking if the sine is oscillating or clipping. Do I need to do anything more sophisticated? At this point, I know nothing of speaker testing. Thanks.
| phase angle? [message #42275 is a reply to message #42273] |
Mon, 25 August 2003 17:35   |
toxicport.e
Messages: 48 Registered: May 2009
Baron |
so how to find phase angle- do use the above equation?? at polytech we are doing series/parallel resonance, I phase angle wrt to Vs etc..i actualy enjoy it!if u know R and reactive part? u can find angle? this will depend on frequency? eg at resonance.below,above. that speaker measureing site is quite comprehensive i likethe manual! mmmmmm trig! :-)
| Thanks and a question [message #42276 is a reply to message #42273] |
Mon, 25 August 2003 18:05   |
artsybrute
Baron |
Thanks Wayne. I'll order the generator tomorrow. One last question: Once I measure the parameters of the woofers, I will be able to determine enclosure volume. But then how would I determine which woofer would work best in the seven cornerhorn, and if the choice would be better than the Eminence woofer?
