Home » Sponsored » Pi Speakers » alternative speakers for Ten Pi
Re: alternative speakers for Ten Pi [message #42232 is a reply to message #42227] Wed, 20 August 2003 10:38 Go to previous messageGo to previous message
To follow up on Wayne's mention of my system, the Kappa 15LF's performed reasonably well in the ten pi enclosures I designed for them. Unfortunately, output (while incredibly loud) is also somewhat chesty, and just didn't have the bottom end I wanted. Additional cabinet bracing would have helped the situation a fair bit, but not enough to fully make up for the difference. As I have nothing to weigh against, I woudl say the project was a modest sucess, although not worth all the work.
Adding a subwoofer to cover the 60 Hz and below region, now wow... That was another story. Having a subwoofer to fill out the bottom octaves truly eliminated that chesty sound from the ten pi's and delivered an excellent sounding system. I'm not sure if this is typical of Wayne's horn design or improper implimentation of the woofer, but the bottom end response simply didn't do it for me. The same driver in a standard ported box, tuned to around 40 Hz was not as loud, but provided a far smoother bass and midbass sound, superior midrange characteristics and deeper response.
Adam
Previous Topic: could i have the 4Pi-18 plans too?
Next Topic: A question about speaker impedence ratings
Current Time: Sun Nov 22 22:31:07 CST 2026
