Home » Sponsored » Pi Speakers » Adjusting the capacitor value on the tweeter attenuator
Adjusting the capacitor value on the tweeter attenuator [message #42196] Sat, 16 August 2003 11:23 Go to previous message
Jerry Parker is currently offline  Jerry Parker
Hey Wayne! Well Mitch and I finally finished building the 3pi's, and they sound good! (They don't look so good though, cause we didnt have time to finish them :-\ ) I did think that the psd2002 still had too much energy though. So what I did was make 2 foot sections of 16awg wire and pull them out of the port on the front. I cut off the old .47mfd capacitor and soldered the jumper wires to the old capacitor lead points. I had some film and foil .33mfd caps around, so i hooked them up instead. something really WIERD is occuring though. I disconnect the capacitor out of the loop, and it seems that it makes NO difference in the sound!!! :-( I find it hard to believe I made the same mistake on BOTH speakers, and it still sounds good, with just a little less midrange. Do you have any idea on what is occuring? I plan on ordering some .22mfd caps in the future to try those out too.
Previous Topic: Who powered up all their amps at once?
Next Topic: 10 Pi horn as an electric bass cabinet
Current Time: Fri Nov 27 04:50:38 CST 2026
