Home » Sponsored » Pi Speakers » pi one pro
pi one pro [message #42130] Thu, 07 August 2003 13:06 Go to next message
Demetrius is currently offline  Demetrius
Wayne, could I have a look at your pi one plans using jbl professional components. Thanks in advance.
Re: pi one pro [message #42131 is a reply to message #42130] Thu, 07 August 2003 16:10 Go to previous messageGo to next message
I don't have a copy in the computer, but I'll try to locate the 1980 plans for the one π speakers that contained the JBL 2115J if you'd like. I'd be happy to scan the file and E-Mail it to you. The cabinet was aligned as per PiAlign, and so the cabinet is small - 0.66ft3 as I recall - and the port had to be mounted diagonally to fit in the box. For different applications, I also installed 2115's in 1ft3 and 2ft3 cabinets with good results. Each of these cabinets was tuned to approximately 45Hz.
Re: pi one pro [message #42134 is a reply to message #42131] Fri, 08 August 2003 06:22 Go to previous messageGo to next message
Thanks Wayne. I'd like to use the larger cabnets tuned to 45Hz. I also wanted to see the crossover used with the 2405's.
Re: pi one pro [message #42137 is a reply to message #42134] Fri, 08 August 2003 12:43 Go to previous message
Connect the 2405H using a second-order network having a 2.0uF cap in series and 0.5mH coil in shunt followed by an attenuator of 8 ohms in series and 4 ohms directly across the tweeter. For the 2115H, use a 0.5mH coil in series. If you run a 2115J, then use a 1.0mH coil instead.
Previous Topic: Urgent Port Question
Next Topic: Box uning
Current Time: Sun Oct 25 06:35:56 CDT 2026
