Home » Audio » General » ART Radio is online NOW!
Re: Technical Question for Skip Pack [message #4207 is a reply to message #4204] Mon, 16 April 2007 18:52 Go to previous messageGo to previous message
It' dead simple. When you go to the main window of any of the ART
topical forums, there's an "ART Radio" link between "Home" and
"Posting Rules". Clicking on that brings up a small window, and,
at least on Windows, opens the download manager. It tells you about a
file named "play.pls", which you want to download to your disk. It's
a one line text file and the .pls suffix means that it's a playlist.
You could open it with Itunes or Windows Media Player, for example,
and then ART Radio would stream though your computer's sound card.
For the Squeezebox, move the file to the directory where you keep your
files for the Slimserver database access and purt it at the top level
so it will index at your first browsing level. I renamed "play.pls" to
ART_Radio.pls so I could easily spot it. Then you bring it up on your
Squeezebox display and hit play. It'll take a few seconds to buffer,
and then it plays. Worked flawlessly for me for over an hour or so
yesterday.
Previous Topic: Registered this Morning
Next Topic: 4WD Suggestions - Vibration...
Current Time: Mon Nov 02 01:40:35 CST 2026
