Home » Sponsored » Pi Speakers » 10 Pi questions
10 Pi questions [message #42025] Fri, 25 July 2003 08:24 Go to next message
Jim D. is currently offline  Jim D.
Wayne,
You sent me some sketches for your 10 folded horn a little while back. Can you help me understand the orientation of the LF driver? I'm having a problem figuring out how the driver box fits into the horn.
Would it be possible to modify this design to be shorter and deeper. I'd like something in the 30" to 36" height. I see that one person is sitting the 10 on it's side but this doesn't seem optimum for space efficiency.
BTW, I'm looking for something horn loaded to sit an Oris horn on like Shanko is doing.
Thanks!!
Jim D.
10 Pi answers [message #42026 is a reply to message #42025] Fri, 25 July 2003 10:07 Go to previous messageGo to next message
Hi Jim!
Did I send you the plans? If not, you may want to tell me your E-Mail address and I'll send you the plans. The woofer faces towards the folds, the first panel is sloped 45o from the face of the motor cabinet.
I think it's a super combination with the Oris, as Shanko is doing.
Wayne
Re: 10 Pi answers [message #42027 is a reply to message #42026] Fri, 25 July 2003 11:21 Go to previous message
Wayne,
Yes you sent me the plans. I'll print out the files and see if I can better understand how the LF motor box fits in.
Thank you,
Jim D.
Previous Topic: Impedance question, please help me Mr. Wayne
Next Topic: A COMPLETELY Non-Pi question...
Current Time: Fri Oct 30 02:10:19 CDT 2026
