Home » Sponsored » Pi Speakers » Choose a match loudspeaker and x-over question.
Thank's Mr. Wayne, but need some more explanation. [message #41980 is a reply to message #41976] Sun, 20 July 2003 18:32 Go to previous messageGo to previous message
Gabriel is currently offline  Gabriel
Dear Wayne,
Thank's for your explanation. But I still confused with your explanation. You said :
"However, if one subsystem is 10dB more efficient but handles 10 times less power, then you really have a matched system even though power requirements are different. At maximum power, both subsystems will generate about the same SPL. Simply attenuate the higher-efficiency subsystem by 10dB, or raise the power of the lower-efficiency subsystem to match."
*Do you mean I need to buy another amp for high freq? Or I still can make it with one amp, but lookin for the mid and high loudspeaker that the sensitivity is 10dB lower (I think I must use an attenuator or L-pad here) than my woofer, and power handling around 50watts is match with my woofer?
*And for the passive filter, do I need to make sub with 2way (with low frequency overlap) filter or build a three way filter?
Thank's in advance.
Regards,
Gabriel Temmy
Previous Topic: This is what happens when you put 2 Delta Pro's, etc,etc...
Next Topic: high effeciency 8"
Current Time: Fri Oct 30 11:05:13 CDT 2026
