Home » Sponsored » Pi Speakers » impedance compensation,
Re: impedance compensation, [message #41961 is a reply to message #41958] Fri, 18 July 2003 10:42 Go to previous message
You could certainly use tank circuits to compensate for the peaks caused by mechanical and Helmholtz resonances. But such a filter will also change overall system tuning, so you would need to look at that and analyze the system as a whole.
Zobels and plain shunt resistance are dampers that will help with the tank circuit formed by interaction of the voice-coil and the crossover capacitors. They'll obviously have some effect on mechanical resonance too. But a Zobel will have very little effect because its impedance is high at low frequencies. And a shunt resistance will not damp mechanical resonance much either unless the value is prohibitively low.
Previous Topic: Studio 2 coaxial pic
Next Topic: If I were to put 2 Delta Pro's in an 8.5 cu ft cab with 2- 5" diaX4 1/4" long.....
Current Time: Thu Oct 29 12:18:11 CDT 2026
