Home » Sponsored » Pi Speakers » BAH stupid JBL recones!
I forgot... [message #41896 is a reply to message #41894] Fri, 11 July 2003 06:51 Go to previous messageGo to previous message
Yes, if you wanna go deeper bass wise, you'll need the mass increase - & the ring provides the best solution in this regard. It is, however, possible to get the increased mass in other ways - for example by gluing it to the centerdome of the diaphragm.
But remember, this will change the units HF behaviour - the gluing solution I mean! But as far as I recall, you cross-over pretty low, so I doubt it will be a problem - but you do need to know how much mass is needed. And don't forget, the overall efficiency of the driver will be reduced - the usual battle between LF extension & efficiency.
Having not tried the trick with gluing added mass to the centerdome myself, I hope somebody else will chime in about experiences in this regard. Oh & I need to remind you, gluing things to the drivers centerdome will increase it's moving mass, but NOT it's re-sale value ;-)
Previous Topic: Theater 4 Pi Driver Screws
Next Topic: Shipping
Current Time: Thu Oct 29 11:10:23 CDT 2026
