Home » Sponsored » Pi Speakers » PSD 2002 modifications
Measurements [message #41884 is a reply to message #41879] Thu, 10 July 2003 22:11 Go to previous messageGo to next message
You might try Speaker Workshop a shot. You can download it free and it works with your PC soundcard. It even has an online support forum, so you might want to give it a go.
Re: and a good thought at that. [message #41886 is a reply to message #41883] Thu, 10 July 2003 22:38 Go to previous messageGo to next message
You wanna sell 'em? I need two.
Adam
Re: Measurements [message #41887 is a reply to message #41884] Thu, 10 July 2003 22:38 Go to previous messageGo to next message
Thanks dude.
I downloaded the program, I'll take a boo at it tomorrow... Dunno what kinda mic I'll have access to for my computer, tho.
Adam
Sorry, but I'm going to hang on to them... [message #41888 is a reply to message #41886] Thu, 10 July 2003 22:55 Go to previous messageGo to next message
...and maybe even mod them with the hot knife.
Thomas F.
Re: Mic for Measurements [message #41891 is a reply to message #41887] Fri, 11 July 2003 03:07 Go to previous messageGo to next message
Check out the TruRTA web site. They have a list of mics and amp combos available at places like Guitar Center that will work well for $60-$100.
Re: Sorry, but I'm going to hang on to them... [message #41897 is a reply to message #41888] Fri, 11 July 2003 08:55 Go to previous messageGo to next message
Damn you.
:D
Adam
Re: Mic for Measurements [message #41905 is a reply to message #41891] Sat, 12 July 2003 09:34 Go to previous messageGo to next message
Can't find TruRTA in google. Do you have a URL?
Thx, Chris
Re: Mic for Measurements - SORRY! [message #41910 is a reply to message #41905] Sat, 12 July 2003 19:41 Go to previous message
Behringer ECM8000 Omnidirectional Measurement Microphone
This microphone is generally available at music stores for around $40.00. It is an electret condenser type and requires phantom power (+15 to +48 VDC) from the preamp in order to operate. You will need a mic preamp that supplies phantom power in order to use the mic with your computer sound system. Based on the frequency response curve provided with the microphone the response appears to be within plus-or-minus 1 dB from 20 to 20 kHz.
Behringer UB802 Microphone Mixer
The UB802 has two microphone input channels with switchable 48 VDC phantom power as required by the ECM8000 microphone above. This unit is generally available for about $69 in music stores.
Behringer MX602 Microphone Mixer
The MX602 has two microphone input channels with switchable 48 VDC phantom power as required by the ECM8000 microphone above. This older mixer is still generally available for about $69 in music stores. (compare to the UB802 above)
Behringer SHARK DSP110 Multi-Function Microphone Preamp
Behringer’s DSP110 preamp is available for about $69.00 at music stores. It provides the phantom powering required by the EMC8000 microphone (above). This unit is much more than just a preamp as it includes a number of digital processing functions. Even with all the extra functions this is still one of the least expensive mic preamps available. The DSP110 is also available from the above Internet sources. The biggest problem you might have with this unit is turning off all the special features!
Rolls MP13 Mini Mic Preamp
This is a very basic single channel preamp that can supply 36 VDC of phantom power to professional grade balanced microphones such as the ECM8000 above. It has both balanced and unbalanced input as well as balanced and unbalanced outputs. A single control varies the gain from 6 dB to 50 dB. A push button switch turns the phantom power on and off. It typically costs about $89 in music stores
Audio Buddy, Dual Mic Preamp
The Audio Buddy is a two-channel mic preamp that costs about $85.00. It provides phantom power but the voltage is not specified and may be only 9 VDC. This may or may not be adequate to power the EMC8000 mic as the mic specifies a range from 15 to 48 VDC. We mention this preamp here only because so few inexpensive products are available.
Here are links to some Internet sources for the above items:
Lentines Music: http://www.lentines.com
8th Street Music: http://www.8thstreet.com
Musicians Friend: http://www.musiciansfriend.com
Previous Topic: super tweeter for Pi 4 T
Next Topic: JBL2226H+MAC40s+large room=Kick ass
Current Time: Fri Nov 13 05:43:57 CST 2026
