Home » Sponsored » Pi Speakers » How well does baltic birch finish?
Re: How well does baltic birch finish? [message #41852 is a reply to message #41747] Wed, 09 July 2003 12:27 Go to previous message
garyhope is currently offline  garyhope
I'm a furniture designer and artist and have used Baltic birch a lot for various furniture pieces.
Birch doesn't take some stains evenly because of the variation in grain, hardness and softness of some of the wood or plys. It depends on the color or stain. It does take a translucent white stain pretty well which gives you a nice blond color. You can brush the stain on with a foam brush and then wipe it down with a rag before sanding and sealing and finishing with a clear or satin coat. You could try ash plywood if you want a nice even finish color, but it's probably more expensive per sheet.
Previous Topic: Crossover values for Drivers with different Impedance??
Next Topic: Diffraction and Baffle Spacing - critic this design?
Current Time: Thu Nov 05 23:42:30 CST 2026
