Home » Sponsored » Pi Speakers » Help on making driver measurements, please?
Re: Woofer Tester [message #41777 is a reply to message #41762] Tue, 01 July 2003 19:05 Go to previous messageGo to previous message
AstroSonic is currently offline  AstroSonic
I have been using the Woofer Tester for about 3 years with no problems. I purchased one after checking the two reviews in Speaker Builder: David Weems in Issue 5/97 and Vance Dickason in issue 5/94. Both reviews were quite favorable and turned up no significant flaws. Both considered it to be an excellent buy at $399 in 1994 and $249 in 1997. After several years of measuring T-S parameters manually the Woofer Tester is a real joy to use. I have seen a couple references to its not working here on this forum and wonder where it started. Perhaps somebody can clarify. In any case, I have found it to be easy to use and reliable. I have used it with Windows 95 and 98, but had some difficulty with 2000 (then again, so did the computer - ended up taking it off). Too bad if it is really discontinued. One would certainly be worth picking up used.
Regards,
AstroSonic
Previous Topic: TAD-JBL-Pi 3-way update
Next Topic: Holism and Reductionism - Fourier Series
Current Time: Sun Nov 01 01:49:51 CST 2026
