Home » Sponsored » Pi Speakers » wedge for corner horns
wedge for corner horns [message #41645] Tue, 17 June 2003 11:41 Go to next message
Hi Wayne,
I've been thinking about your corner horn design, and the
one thing that's been bugging me is that as designed, the sound
waves are being focused into a corner, then reflecting past each
other to be sent into the room around the sides of the cabinet.
Can you comment on placing a wedge in the corner as a reflector?
I've attempted a top view ascii version below. Assume everything
is at 45/90 degrees and the point of the wedge would be against
the baffle board.
Thx, Chris
|__|
Re: wedge for corner horns [message #41646 is a reply to message #41645] Tue, 17 June 2003 11:44 Go to previous messageGo to next message
OK, so the ascii art and html aren't compatable... hrumph.
It looked good in my xterm. :^)
Re: wedge for corner horns [message #41647 is a reply to message #41646] Tue, 17 June 2003 13:39 Go to previous messageGo to next message
Sonar_Vermin is currently offline  Sonar_Vermin
What you have to do is hard-code all of the spacing. Or include a line-art drawing of your idea. I suggest GIMP.
Put the image file somewhere that Apache can find it, and stick it in your post.
Peace,
--Shannon
Re: wedge for corner horns [message #41648 is a reply to message #41645] Tue, 17 June 2003 14:29 Go to previous messageGo to next message
Maybe this will work better...
# |__|
Re: wedge for corner horns [message #41650 is a reply to message #41648] Tue, 17 June 2003 15:02 Go to previous message
This wedge is a good idea, but surprisingly, you'll find that it doesn't make a noticeable difference. I used this exact sort of reflector in early prototypes and for the same reason you suggested - It would appear to direct on-axis sounds better. But I found no difference when I installed such a wedge.
Check out John Sheerin's wave mapping animation. It shows the movement of a wavefront past reflectors such as these.
Previous Topic: triamp Q for Wayne
Next Topic: help for crossover
Current Time: Mon Nov 02 19:00:50 CST 2026
