Home » Sponsored » Pi Speakers » changing ports
changing ports [message #41560] Sun, 08 June 2003 17:24 Go to next message
Hello All,
I'm working on a single driver design, and I want to try using a ported dual chamber box. The dimensions work out at 2 1/2" in diameter at 3/4" length using a single port box. Anybody know the formula to convert one vent to two? I would like to keep the vent length at 3/4" as that's also the front panel thickness. (No, I'm keeping my Pi's. I just acquired a pair of Moth Cicada drivers and want to play with them.)
Thanks in advance,
Steve
Re: changing ports [message #41561 is a reply to message #41560] Sun, 08 June 2003 20:35 Go to previous messageGo to next message
I may have solved my problem. I get two vents 2" in diameter.
Re: changing ports [message #41562 is a reply to message #41560] Sun, 08 June 2003 20:58 Go to previous message
Hi Steve!
PiAlign doesn't calculate dual ports, but it does suggest a box volume and single port dimensions along with the Helmholtz frequency that the box will be tuned to. So you can use the box volume and frequency with programs like BoxPlot that will calculate multiple ports.
Wayne
Previous Topic: Best bang for the buck - Theater 4 Pi plan request
Next Topic: Wayne, Theater 4 Pi plan request
Current Time: Sun Nov 29 02:13:26 CST 2026
