Home » Sponsored » Pi Speakers » Pi 500 Hz Xover for 515B/511B???
You've got mail! [message #41518 is a reply to message #41517] Fri, 30 May 2003 11:44 Go to previous messageGo to previous message
Check your E-Mail because I've sent the π crossover schematics to your E-Mail address. There are crossovers listed with 500Hz, 600Hz, 800Hz and 1.6kHz crossover points. You'll find a chart of values for different amounts of attenuation/augmentation included with each schematic, and all these were worked out using Spice. If you're interested, there's also a 1kHz π crossover discussed in an earlier post called "1kHz crossover values."
Lots of people have built π speakers using Altec horns, and the π crossover works very well in this application. I suggest that the 6dB version be used for flattest on-axis response, but that usually leaves the HF horn about 4dB louder than the LF subsystem, if it is a direct radiator or undersized horn. One way to get around this is to use the π cornerhorn configuration and I highly recommend this approach.
Previous Topic: Pi Subs
Next Topic: need help what driver in this basshorn
Current Time: Tue Oct 06 22:06:33 CDT 2026
