Home » Sponsored » Pi Speakers » Suggestions for horn sub needed
Suggestions for horn sub needed [message #41488] Sat, 24 May 2003 12:25 Go to previous message
Triodeuser is currently offline  Triodeuser
Thinking about Labsubs - but they're a little large -
I might could use a cornerhorn - but in one of the corners there is only about 3 ft of side wall before there is a french door that indents about 3" or so from the trim. I usually leave that particular door closed.
BTW Kudos to Michealz for his implentation below. I also like David Shanks Implentation although I'm not sure I have enough wall space for that configuration
I'm using 1 meter fiberglas horns with a LeCleac'h flare that I plan to crossover at around 135hz or thereabouts.
I'm using tube amps (300B's now, GM70 later) and would probably run the subs active and push them with some rebuilt Dynaco MKlll's.
Appreciate any and all input on this. I've just started looking at this aspect of my system.
Thanks
Ken L
Greenville SC
Previous Topic: Compression Drivers arrived !!!
Next Topic: Theatre 7 cornerhorns
Current Time: Sat Nov 28 19:53:30 CST 2026
