Home » Sponsored » Pi Speakers » Compression Drivers arrived !!!
Formulas [message #41485 is a reply to message #41484] Sat, 24 May 2003 06:33 Go to previous messageGo to previous message
You will need to use the formulas for calculating impedance and power through a reactive circuit, which isn't quite the same as pure resistance. The formulas are in the "Pi Alignment Theory" document and in electronics textbooks.
Impedance is found using reactive impedance formulas:
For inductance, XL = 2πFL
For capacitance. XC = 1/2πFC
Where:
XL is inductive reactance, in ohms
XC is capacitive reactance, in ohms
F is frequency, in Hertz
L is inductance in Henries (so mH is H x 10 -3)
C is capacitance in Farads (so uF is F x 10 -6)
This will tell you the impedance of your coils and caps.
If you know the voltage across a component and its impedance, you can calculate the power dissipated by the device using the formula P=E2/Z. If you know the current flowing through a device, you can find power by using P=I2Z. So find the reactive impedance of the device in question at the desired frequency, and substitute that for "Z."
Previous Topic: wayne - theatre 7 crossover question
Next Topic: Suggestions for horn sub needed
Current Time: Sat Nov 28 20:06:50 CST 2026
