Home » Sponsored » Pi Speakers » Which PI speakers to build?
Find a tape measure . . . [message #41214 is a reply to message #41211] Sat, 03 May 2003 13:24 Go to previous message
Tightwad is currently offline  Tightwad
. . . and see just how big those suckers are. If you got that much room, you also might have free corners and should consider cornerhorns.
If I had the room, I'd be all over 'em.
If you wanna get some ideas for finish, options, wood horns, etc, check out the link.
Previous Topic: Is there a good substitute for r13?
Next Topic: Question regarding McBeans' Horn Resp program
Current Time: Tue Oct 20 22:00:23 CDT 2026
