Home » Sponsored » Pi Speakers » HF Horn-Woofer phase at crossover
Jet-Hot [message #41193 is a reply to message #41191] Thu, 01 May 2003 20:33 Go to previous messageGo to previous message
Regarding metal coating and finishes, try Jet-Hot for a real treat. That's the ticket for headers - I've got it on the Olds. Then again, powdercoat is probably just as good for this application, and definitely a lot cheaper. But when running metals red-hot, this Jet-Hot ceramic coat is the real deal.
You won't believe this stuff until you see it with your own eyes. You'll think I'm exaggerating. But the facts are that you can watch your headers glow red-hot and not damage the finish with this treatment. It's a silver finish that looks very much like polished aluminum and feels like plastic or vinyl. It lasts several years and keeps your tube headers from rusting or heat fatigue. Not only that, but 15 minutes after running - and seeing the tubes glowing red-hot - you can touch the headers and not get burned. It directs heat away so well that most heat passes out the pipes rather than being conducted through the metal. That also keeps your starter and other nearby peripheral assemblies cool. The coating is some form of ceramic that can expand and shrink with the change of metal at temperature. You can get it in a variety of finishes, with black and silver being the most popular. Really cool stuff!
Previous Topic: "B" sides
Next Topic: Theater 4 Pi + .5mh in woofer circuit... Wayne ?
Current Time: Wed Oct 14 20:51:47 CDT 2026
