Home » Sponsored » Pi Speakers » Is there a good substitute for r13?
Re: Is there a good substitute for r13? [message #41178 is a reply to message #41176] Thu, 01 May 2003 06:37 Go to previous messageGo to previous message
You can simply peel off the paper from the kraft faced insulation on the R13. You can also purchase R19 unfaced and peel it in half.
If you have concerns about airborne fiberglass. You can go to a commercial insulation supplier, or HVAC supplier in your area. Get 1" high density fiberglass "duct liner" The 1" high density has the same accoustical properties as 3" insulation.
Duct liner in inside almost all commercial air conditioning ducts. Lots of people breathing it all day long. Dont know if that makes it better!
Bill
Previous Topic: B&C vs P.Audio compression drivers
Next Topic: Which PI speakers to build?
Current Time: Tue Oct 20 18:41:52 CDT 2026
