Home » Sponsored » Pi Speakers » Valvestate problem
Valvestate problem [message #41105] Mon, 21 April 2003 12:02 Go to next message
AmpKiller is currently offline  AmpKiller
Hi, I have a Valvestate which just makes a low noise when I switch it on. I've been able to start it by using a speaker cable which is open on one side (no plug, so I can see the two cables inside). Then after switch it on I quickly touch the two cables from the side without connector and then the amp starts allright. I see a spark. (Odd isn't it?)
Can anyone make a guess what's wrong with the amp? How can I fix it? Thanks.
Re: Valvestate problem [message #41106 is a reply to message #41105] Mon, 21 April 2003 12:51 Go to previous messageGo to next message
Maybe you have a bad tube?
Re: Valvestate problem [message #41109 is a reply to message #41105] Tue, 22 April 2003 11:42 Go to previous message
Hi Wayne!
Thanks for your info! I'll check the tube soon. I just opened the amp (I was out of use for at least 2 years) and found some cables in very bad condition. One of the guesses I got was about a bad connection which somehow was fixed after shorting the circuit with the speaker cables. I'll repare the cables and see what happens, if it still does not work I'll check more bad connections and the tube.
Thanks a lot for your help!! I'll post the results here.
Best regards,
Jose
Previous Topic: 1Pi problems
Next Topic: Wayne -- anyone? Dual ducted vents possible w/Pi Alignment?
Current Time: Wed Oct 14 22:52:54 CDT 2026
