Home » Sponsored » Pi Speakers » Sub enclosure for 10" mid within bass cab.? Bmar? Wayne?
Sub enclosure for 10" mid within bass cab.? Bmar? Wayne? [message #40827] Thu, 03 April 2003 06:56 Go to next message
Hi guys,
I'm putting together Dave Cope's three ways and need to know how small an enclosure the 10" JBL's can live with within the bass cabinet for the 15" TAD drivers. I don't want to use up more of the bass cabinet's volume than neccesary. I was thinking of a box with an internal volume of .42 cu. ft. Is this too small for the JBL 10"? I think maybe Bill M. might have advised on this but I can't find any record in my notes.
Thanks!
Garland
Re: Sub enclosure for 10" mid within bass cab.? Bmar? Wayne? [message #40828 is a reply to message #40827] Thu, 03 April 2003 07:21 Go to previous messageGo to next message
Hi G,
a .4 box would be good. To split hairs, I think I was planning to be around .5
It's my impression that the smallest box you could build around the 10" will be big enough for the band width it will be used in.
I think your right on the money with the small box and not use anymore of the 15" driver space than necessary.
Bill
Re: Sub enclosure for 10" mid within bass cab.? Bmar? Wayne? [message #40830 is a reply to message #40827] Thu, 03 April 2003 07:58 Go to previous messageGo to next message
Are these 2123's? The graph for those on JBL's site shows
response in a 0.25 cu ft box.
Chris
Drool. Slobber. ;-) n/t [message #40831 is a reply to message #40827] Thu, 03 April 2003 08:54 Go to previous messageGo to next message
DRC is currently offline  DRC
nt
Keep your ears and your mind open.
Subenclosure volume [message #40834 is a reply to message #40827] Thu, 03 April 2003 09:27 Go to previous messageGo to next message
Hi Garland!
I put them in a 720 cubic inch sealed subenclosure, which is about 0.4 cubic feet. The volume isn't terribly critical as long as it doesn't shove the f3 point up above your crossover frequency. But you don't want it small enough that the system becomes underdamped, because it will make the midrange peaky and cause it to sound "throaty" down low.
Wayne
Thanks!... and Dave, just a little bit longer...! (nt) [message #40837 is a reply to message #40827] Thu, 03 April 2003 09:44 Go to previous message
nt
Previous Topic: Horn Designs for brand X drivers
Next Topic: Raw, Stark and unrefined... more of the same
Current Time: Wed Jun 26 05:58:00 CDT 2024
