Home » Sponsored » Pi Speakers » Hornresp MMD spec
Hornresp MMD spec [message #40736] Thu, 27 March 2003 01:54 Go to next message
Hey everyone.
Am using Hornresp now, and it needs something called Mmd. Is this the same as Mms? If not, how can I calculate Mmd from the other t/s specs?
Thanks!
Adrian
Re: Hornresp MMD spec [message #40738 is a reply to message #40736] Thu, 27 March 2003 11:23 Go to previous messageGo to next message
Smrtislav is currently offline  Smrtislav
Hi, in almost every window in the driver parameters section pressing pops up a window, where you put T/S parameters in and the program computes the value. Or it is in the menu under Tools-Convert parameter.
K.
Re: Hornresp MMD spec [message #40739 is a reply to message #40736] Thu, 27 March 2003 11:33 Go to previous messageGo to next message
MMD is the moving mass of the diaphragm. There is a conversion tool that is made available when you double-click on this parameter in edit mode. Just click twice and Hornresp will ask you some questions and then calculate MMD for you using the information provided.
Thanks Guys (NT) [message #40749 is a reply to message #40736] Thu, 27 March 2003 16:10 Go to previous message
Previous Topic: b&W 802 series80
Next Topic: Can somebody please tell me if this Tractrix design is correct
Current Time: Sat Nov 28 23:04:05 CST 2026
