Home » Sponsored » Pi Speakers » Pi Align question
Pi Align question [message #40680] Wed, 19 March 2003 09:28 Go to next message
Anonymous
Hypothetical;
Pi Align;
If the software tells me that internal box volume is 4 ft^3,
port diameter is 4", port length is 12", then;
1. Do I need to increase the box volume to offset
the woofer displacement inside the box ?
2. Do I need to increase the box volume to offset
the port displacement inside the box ? if no,
do I need to take into consideration the thickness
of the port. Suppose the port is 4" I.D. and 8" O.D.,
do I need to factor in the port thickness as occupying
space inside my box?
I'm looking for the technically correct answer on the
theory.
Re: Pi Align question [message #40681 is a reply to message #40680] Wed, 19 March 2003 09:37 Go to previous messageGo to next message
Jeff Robinson is currently offline  Jeff Robinson
1: yes
2: yes
No software can put in displacement adjustments without specific info on the items involved (and most don't include any adjustments at all). You also need to adjust the internal displacement for any bracing and any other speakers, horns etc. A popular rule of thumb is to build in at least a 15% fudge factor and add bracing until the box tuning is correct (involves measuring the system impedance curve to calculate the system H and Alpha values).
Jeff Robinson
thanx nt [message #40684 is a reply to message #40681] Wed, 19 March 2003 11:32 Go to previous message
Anonymous
Previous Topic: Other JBL woofers
Next Topic: SACD
Current Time: Sat Oct 17 19:45:09 CDT 2026
