Home » Sponsored » Pi Speakers » Heres an interesting little compression driver/horn combo
Heres an interesting little compression driver/horn combo [message #40555] Thu, 06 March 2003 03:04 Go to next message
http://cgi.ebay.com.au/ws/eBayISAPI.dll?ViewItem&item=3010532690&category=
Was browsing this auction, is a pair of real cheap compression drivers on very small 106mm by 60mm horns. 10 bucks! The compression driver brand is JPA, has 18mm throat and stated 800Hz-20KHz response. The auction says its used in Klipsch Heresy Horn speakers. Thought I might as well post this here, maybe get some more info on these if anyone can help, they are only 10 bucks so what the hell, I might as well buy them! Am not expecting anything great, thats what my JBL/P.Audio combo is for :) but they would be fun to muck around with.
Anyone got any comments on these drivers?
Thanks!
Adrian
Re: Heres an interesting little compression driver/horn combo [message #40556 is a reply to message #40555] Thu, 06 March 2003 03:41 Go to previous messageGo to next message
Bubbawat is currently offline  Bubbawat
Doesn't sound like a Heresy driver to me - while the drivers have changed over the years, the Klipsch heresy is a three way with the mid horn (squawker) generally crossed over at about 700hz going to a tweeter horn around 6k (maybe wrong here - 6k is probably the high side). That fuller range would only be on the Klipsch reference stuff.
Re: Heres an interesting little compression driver/horn combo [message #40570 is a reply to message #40556] Fri, 07 March 2003 00:00 Go to previous messageGo to next message
Kewl, thanks for your help. Do you think they are worth getting at all, they arn't very expensive, or are they just crap stuff?
Re: Heres an interesting little compression driver/horn combo [message #40571 is a reply to message #40570] Fri, 07 March 2003 03:49 Go to previous message
Don't know at all - but $10 is a very cheap mistake if they aren't any good - go for it.
Previous Topic: Yeah, but what about the damn SACD??!!
Next Topic: For those of you who are audio veterans, this is for you!!!!!!!!!!!!!
Current Time: Sun Nov 01 11:12:16 CST 2026
