Home » Sponsored » Pi Speakers » I need the Kick to kick drums
bridged mono the 555 does 600 watts [message #40442 is a reply to message #40439] Thu, 27 February 2003 14:43 Go to previous messageGo to previous message
and will bring down your walls in that application. I faced a single EV 15bwk driver against the wall, near a corner, driven by a measly 1875 chip amp...30 feet across the room all kinds of stuff was rattling and buzzing, and this was at "reasonable" levels. If you DO use the 555 for subwoofer duty, check or replace the 47uF caps in the feedback loops, my 545 had "premature" roll off at the low end in one channel which drove me batty swapping speaker polarity till I figured out it was the AMP stupid. You may be just as well off to use a "plate amp" from PE, one with a remote control would be nice for setting the level from the listening position, and the built in bass boost won't hurt. Then you can drive the Theater 4's with the adcom:)
adcom 555 driving jbl 4648a-8's
adcom 545 driving altec 902/511's
marchand xm9L set at 800Hz.
ginger baker sounds a hell of a lot better in my LR than my neighbor's drums from across the alley behind my house:) Sam
Previous Topic: Speakers plans
Next Topic: How do I determine the inductance of a Woofer
Current Time: Sun Nov 01 23:38:45 CST 2026
