Home » Sponsored » Pi Speakers » Does the JBL 2370 HORN use screw on or bolt type mounting???
Does the JBL 2370 HORN use screw on or bolt type mounting??? [message #40430] Thu, 27 February 2003 00:56 Go to next message
Hey everyone. Cant seem to find this info anywhere, even though its probably staring me in the face lol. I was about to order a pair of JBL 2370 horns, then I just remembered, I have no idea wheather it uses screw or bolt type mounting!!! The compression driver I want to use with it is bolt type, probably 2 or 3-bolt. So if anyone can tell me what the 2370 uses that would be great! Thanks! Adrian
Standard 3-hole bolt-on mount [message #40431 is a reply to message #40430] Thu, 27 February 2003 01:24 Go to previous messageGo to next message
The JBL 2370 uses the standard 3-hole bolt-on mount as its only connection method.
Re: Standard 3-hole bolt-on mount [message #40433 is a reply to message #40431] Thu, 27 February 2003 04:46 Go to previous messageGo to next message
Hey, thanks for the info. I just hope the 2370 is the 2370A! Im not actually sure if the one I'm ordering is the A version or not, if it isn't though, would it be safe to bet that theres little difference between the two? Thanks! Adrian
they are the same wayne! [message #40459 is a reply to message #40433] Fri, 28 February 2003 15:19 Go to previous messageGo to next message
Hey Wayne, just thought you might be interested to know I contacted JBL Professional and they have told me the 2370 is the 2370A! So I'm happy :) Cant believe I picked up a pair of these horns for around US$30 a piece..... ! And theres still 4 left, maybe I'll snatch them all up!
I've seen references [message #40462 is a reply to message #40459] Sat, 01 March 2003 06:39 Go to previous messageGo to next message
where it was claimed the older 2370 was made of thicker fiberglass than the present 2370A's. Other than that, as long as they are undamaged, you are getting a great price. Are you CERTAIN that the Paudio drivers will work for you as well as the psd-2002's Wayne normally specifies? Sam
Re: I've seen references [message #40463 is a reply to message #40462] Sat, 01 March 2003 06:54 Go to previous message
Hey Sam. The response I got from JBL was not to worry at all, as they are "one in the same" so I'll just take I shouldn't worry about any differences :)
Have not heard of the psd-2002's before, but all the feedback I've gotten for the P.Audio stuff has been good so far. The other reason I've choosen P.Audio is that in Australia I can get them at great prices. Unless you have suggestions for other ones.....?
Adrian
Previous Topic: One Pi/Two Pi driver level adjustment?
Next Topic: Re: Pi Speakers
Current Time: Sun Nov 08 05:06:37 CST 2026
