Home » Sponsored » Pi Speakers » P.Audio SD-450 N on JBL 2370 Bi-Radial Horn with Wayne Parhams compensation circuit
Re: Flanges [message #40418 is a reply to message #40416] Tue, 25 February 2003 06:09 Go to previous messageGo to previous message
Hi Adrian,
If you decide to make the throat's from wood. I suggest using baltic birch plywood glued up to make 1.750 thickness. You will need the very thin laminates for flange strength. I believe making the flange itself 5/16 (8mm) thick will be good.
Bill
Previous Topic: Pi 10 build idea
Next Topic: 10 Pi Plans
Current Time: Thu Nov 19 10:22:04 CST 2026
