Home » Sponsored » Pi Speakers » P.Audio SD-450 N on JBL 2370 Bi-Radial Horn with Wayne Parhams compensation circuit
two cents from a 2370 user [message #40395 is a reply to message #40378] Sun, 23 February 2003 21:23 Go to previous messageGo to previous message
Adrian,
if you decide to go with JBL I can say the sound is superb for hi-fi or pro use. Since you make dispersion a priority I think you would like it as the dispersion is incredible(diffraction slot). I built my Pi speakers using 2370's and I love em. You can certainly find more attractive horns, but they look better than other plastic horns they even look better than a lot of metal horns. For the price you mentioned they are a steal. You will not find a better horn(your subjective mileage may vary).
*note in my experience 2370's need less compensation than many other horns. A .33 or .22mF should work fine, but that depends on the compression driver. I remember thinking the P Audio had good top end when I considered it a while back. It should do great.
Have fun!
Thomas
Previous Topic: Pi 10 build idea
Next Topic: 10 Pi Plans
Current Time: Mon Oct 05 14:17:47 CDT 2026
