Home » Sponsored » Pi Speakers » 3" open cell foam insulation
3" open cell foam insulation [message #40386] Sun, 23 February 2003 09:28 Go to next message
frog is currently offline  frog
I am wondering if I can use 3" open cell foam insulation instead of R11 or R13 fiberglass in my 2 PI speakers. I already have a few sheets of it, and I hate working with fiberglass. If anybody knows if it will work I would love to hear from you. Thanks.
Re: 3" open cell foam insulation [message #40390 is a reply to message #40386] Sun, 23 February 2003 14:44 Go to previous messageGo to next message
Sorry, I can't comment on the product you have in comparison with R11 and R13. I use some closed cell foam products as a fill and they work quite well, acting as a solid mass and a damper. But I don't know if the product you are talking about will work as a suitable replacement for R11 or R13 in this application. I suppose it couldn't hurt to try. For a test - Listen to the port closely with your ear. The midrange should sound distinctly muffled, and as absent as possible. If that isn't the case, then the foam product isn't sufficient and you should replace it. But if the midrange is sufficiently attenuated, you're good to go.
Thanks Wayne [message #40391 is a reply to message #40390] Sun, 23 February 2003 15:32 Go to previous message
Thanks Wayne
Previous Topic: Lima Vinyl
Next Topic: 2Pi and sound quality
Current Time: Mon Oct 05 18:26:59 CDT 2026
