Home » Sponsored » Pi Speakers » Impedance peak
Impedance peak [message #40348] Wed, 19 February 2003 11:05 Go to next message
Pilkar is currently offline  Pilkar
Hi everyone!
I was looking the datasheet of the driver i will use, and it has a response graph were it is shown coupled to the horn i will use (lucky me). There is an impedance peak of 13ohms at around 900-950Hz. Since i will be crossing at 800Hz i thought there maybe a problem, like a shift in the crossover frequency. If that is the case, what should i do? Recalculate the crossover components for a 10-13 ohm load?
Well, thats all for now!
Thank you for your help!
Re: Impedance peak [message #40349 is a reply to message #40348] Wed, 19 February 2003 11:44 Go to previous messageGo to next message
An impedance peak of 13 ohms isn't terribly high, and is expected from a horn. There will be a few peaks near the flare frequency and its harmonics. There are also sometimes peaks caused by diaphragm mechanical resonance below the flare frequency, where the horn cannot load the diaphragm. To tame these peaks, and electrically mnatch the driver better with the crossover, I suggest you use a shunt resistor damper. Please see the π Crossover Document for more information.
Re: Impedance peak [message #40350 is a reply to message #40349] Wed, 19 February 2003 14:51 Go to previous message
Thank you very much!
Previous Topic: What is your tolerance for background noise
Next Topic: Hi Wayne: Wooden Horns
Current Time: Thu Nov 26 11:55:36 CST 2026
