Home » Sponsored » Pi Speakers » "wire is wire" dept.
"wire is wire" dept. [message #40206] Fri, 07 February 2003 06:21 Go to next message
Just a heads up that MCM still has some AR brand flat speaker wire on sale that is ideal for BIAMPING. The flat 4 conductors of 16ga. let you run both drivers from one cable, and they are 50 feet for $4.99. The normal 2 conductor AR 16ga. flat wire from Lowes measures some of the LOWEST pF/ft. I have seen, about 1/4 as much as traditional monster cable and zip cord. The flat white jacket lends itself to labeling with a felt tip marker also, and the 16 ga. conductors can fit into VINTAGE amp terminals without difficulty. A pair of 50 ft. spools, and I can biamp anything in the living room with ease. Sam
Re: "wire is wire" dept. [message #40215 is a reply to message #40206] Fri, 07 February 2003 16:56 Go to previous messageGo to next message
Hi Sam,
Do you have a part number? I can't find it.
Thx, Chris
forgot to mention that:) [message #40216 is a reply to message #40215] Fri, 07 February 2003 17:21 Go to previous message
58-7115 @ $4.99. Sam
Previous Topic: Location and size of binding posts on Pi 2 Towers?
Next Topic: New DIY Pi Speaker owner and have build questions
Current Time: Tue Nov 03 18:10:00 CST 2026
