Home » Sponsored » Pi Speakers » New browser; looking for suitable kit for 8 watt 2A3PSE kit
Speaker suggestions for 8 watt 2A3PSE amp [message #40194 is a reply to message #40181] Thu, 06 February 2003 22:57 Go to previous messageGo to previous message
If you need to build a pair of speakers in the $400.00 range, I suggest limiting your choices to the Studio Series one π, two π or two π tower speakers.
If you have $400.00 to spend on each speaker, then I'd also consider any of the Thermionic Series models, or the Theater Series four π or seven π Speakers. The Thermionic Series four's and seven's are probably too large, but the Theater Series four π and seven π Speakers and the Thermionic three's would probably suit you just fine.
Look around on this forum a litle bit and you'll see a lot of discussions and feedback about each of these speakers. Any of them should work well for you.
Previous Topic: Baffle step correction
Next Topic: Wayne, you've got to see the Feb. issue of AudioXpress!
Current Time: Fri Oct 16 20:10:13 CDT 2026
