Home » Sponsored » Pi Speakers » Life beyond 1" ?
Life beyond 1" ? [message #40184] Thu, 06 February 2003 17:41 Go to next message
Hi All
Since this is more or less a self review you'll have to take it for what it's worth! After a few years of listening to various 1" drivers in horns I have now had a change to check out the 2" format in my own cave. I have always thought some of the larger speaker systems sounded very nice at shows and events. Thats never the way things sound at home so the shows are pretty judgmental. I have tested the large 21" horn and it will hold its own to 380hz with a Selenium D405TI The driver is rated for 400-18k. The selenium chart shows good response from 400 to 12K. Thats the range I get a good reading in. -3db @ 400 and -10db @ 12K. Maybe a driver with an extended response in the upper octave would measure better. I will be trying some JBL 2445's in a week and I also have some phenolic 1" drivers to test for low freq 1" results.
I have been listening to 3 cd's primarily. Jimmy McGriff Diana Krall Roger Waters
I choose these because my Kids play Sax and Piano. Along with the organ there is a lot of sax on that cd. I find those two instruments hard to reproduce sounding original. I get a chance to listen to them both frequently. Roger Waters just does some very dynamic music and the low end is always there.
I have listened to a 2way with both a JBL 2226 or a JBL 2245. A different sound from each arrangement. Obviously the 2245 has some balls in the basement. It is not as efficient as the 2226 and the 2226 can be crossed over higher and I think has the edge for smooth.
for gut wrenching low octave. the choice is of course the 18" 2245.
Cross over any where from 400-1600. 400 is a touch too low for my liking but it does have a different sound to itself and is quite enjoyable. 1.6k is standard for a 1" and silly for 2" 500 - 800 is nice. I like 600 best with the 2226 and 500 best with the 2245.
The two way is lacking though, or at least the horn and driver combo I have is. I like a small horn with a 1" driver crossed at 10K. I have been doing all this with an active Xo and I have a little passive unit for the tweeter that I use. It's just a pair of L-pads with a 10K xo that goes to the tweeter side. I generally leave the tweeter un-attenuated, and turn down the main horn 8-10db. the rest
of the attenuation for the horns is done in the active xo.
Maybe with a better 2" driver that has better top end performance a 2way would be great. I'm liking the 3way best of all. In General the 2" format driver I find to be more dynamic than the 1" in the smaller horns. I'm considering taking a new approach to my personal system later this year. I'm really impressed with the way the larger drivers sound.
This is more a review of some new 2" format arrangements and what I have done to hook them up and how they sound together. I'll have some response charts in few days once they get scanned and uploaded.
More things to try in the future will be 1" drivers on the large 400hz horn. 2" drivers on the smaller horns.
Thanks for reading all this,
Bill
Re: Life beyond 1" ? [message #40185 is a reply to message #40184] Thu, 06 February 2003 17:51 Go to previous messageGo to next message
mikebake is currently offline  mikebake
What three way are you refering to?
Re: Life beyond 1" ? [message #40186 is a reply to message #40185] Thu, 06 February 2003 18:03 Go to previous messageGo to next message
The 3way system is the same as the 2way system with an added JBL 2425 1" driver on a small horn. This was also just "added" to the two way active crossover with a simple 1st order passive. no rocket science tonight, just playing around.
Re: Life beyond 1" ? [message #40187 is a reply to message #40186] Thu, 06 February 2003 18:17 Go to previous messageGo to next message
I see. Well, that makes the 3115's a pile of crap. I'll give you what you paid for them...........:) Gettin ready for the big party, dude?? We'll have to start crankin the PR up soon......
MBB
Re: Life beyond 1" ? [message #40188 is a reply to message #40187] Thu, 06 February 2003 18:42 Go to previous messageGo to next message
I really like that 8" driver and horn in the 3115's. This horn is about the same size. It has a different sound to it. I dont consider a lot things better or worse... its just diffent and equally pleasing to listen to.
I'm ready for MAF, for sure. I'll have some regular horns and some big ones to bring. As well I'll have a 12" two way speaker with a horn on top. Maybe another model but time is tight with other work.
I will also be bring an outstanding pair of 7 Pi's with a horn on top that I can post a picture of very soon.
Bill
Re: Life beyond 1" ? [message #40189 is a reply to message #40184] Thu, 06 February 2003 20:32 Go to previous messageGo to next message
hi bill, did you ask the wife about the extra inch? i'm sure she's ecstatic! see you saturday,
george
Re: Life beyond 1" ? [message #40195 is a reply to message #40184] Thu, 06 February 2003 23:07 Go to previous messageGo to next message
Super good stuff.
Thanks for posting. Love your horns, and this post is really good.
Re: Life beyond 1" ? [message #40196 is a reply to message #40188] Thu, 06 February 2003 23:33 Go to previous messageGo to next message
I like the medium-format, cone-driven midrange horns too. Those are my favorite for 200Hz to 2kHz. For that range, I think it's the best way to go.
By the way, what are you gonna do about amplification for MAF?
Re: Life beyond 1" ? [message #40197 is a reply to message #40189] Thu, 06 February 2003 23:35 Go to previous messageGo to next message
Bwaaahaaahhhaaaa!
Maybe 'The Angry Inch'? [message #40202 is a reply to message #40195] Fri, 07 February 2003 03:08 Go to previous messageGo to previous message
...Considering WAF! :)
Previous Topic: Two questions
Next Topic: 2 Pi bracing
Current Time: Thu Nov 19 10:21:13 CST 2026
