Home » Sponsored » Pi Speakers » Wayne: Advice for EV LS12A drivers in Pi Alignment?
Wayne: Advice for EV LS12A drivers in Pi Alignment? [message #40173] Thu, 06 February 2003 10:06 Go to next message
BobCat is currently offline  BobCat
Wayne,
I purchased a pair of mint used vintage Electro Voice LS12A 12" 8 ohm full range drivers from ebay. I would like to incorporate these drivers in a pseudo Pi alignment. Unfortunately, I have no specs on these drivers. Can you help me?
1) Any ideas what type/size enclosure size will work best?
2) Would you use a helper tweeter (piezo or EV T35 or other)?
3) Does anyone have the TS parameters for these drivers?
Many thanks,
BobCat
Advice for EV LS12A drivers in Pi Alignment [message #40176 is a reply to message #40173] Thu, 06 February 2003 12:44 Go to previous message
Search the archives for "Woofer Tester". You'll find ways to measure the speakers with a signal generator and meter or scope, a dedicated woofer tester or a PC program like Speaker Workshop.
Depends on the parameters, but almost everything works well in a π cornerhorn. That's my favorite and it gets my vote. Then again, since it looks like you are going to use the EV's full range - well up through the vocal overtone region - You might prefer to make a standard bass-reflex three π speaker with them.
Can't say without seeing the response chart. If response is good to 3500Hz, then the KSN1038 might work for you.
Someone else here might but I don't, sorry.
Previous Topic: Studio Series 2Pi Comparison(long)
Next Topic: 2pi tower dimensions, using 3/4" mdf
Current Time: Thu Nov 19 13:23:00 CST 2026
