Home » Sponsored » Pi Speakers » three Pi kits
You've got mail! [message #40142 is a reply to message #40138] Tue, 04 February 2003 11:19 Go to previous messageGo to previous message
I've sent the plans to your E-Mail address, but since you have a Hotmail account, they'll probably exceed your space limit. If that happens, I'd be happy to resend if you'll tell me a different place to send.
As for the contents of the kit, each contains enough parts to build one speaker, so for a stereo pair you'll need two. Kits include the speaker drivers, the connector panel, hook up wires, "π" logo decal and a printed copy of the plans. For larger speakers that incorporate a compression tweeter and crossover network, kits also include the crossover, tweeter compensation cable assembly, Zobel woofer damper, and all cable assemblies are completed and ready to install. Every kit containing a compression driver also includes the horn flare and the bolts to mount the driver to the horn.
Previous Topic: a small update
Next Topic: Plywood vs. MDF
Current Time: Thu Nov 19 17:03:38 CST 2026
